donnysparks
Hi I'm looking for a bit of advice. I have 2 velux windows to connect up & each one has a flex with a plug top so straight forward enough, only problem is there's no attic space above otherwise I'd fit a socket & plug them straight into it, they don't want a switch on the ceiling or wall either. My thought was to run a 2.5t+e between them back to a socket in the far away attic space. This would mean cutting the plugs off them & putting them both through straight connection plates. Thought this would be better rather than fitting the sockets in the ceiling void & sheeting over them. Any thoughts?
Thanks in advance
Thanks in advance
I have four in my house and I wired them to fcu's from a ring main.
Arrgh moulded plugs. First off ask Velux, I did and they said cutting off their plug tops would void their warranty, I can feel davesparks alarm bells sounding now.
I step in on his behalf lol.. regardless of what velux say you cannot invalidate the warranty by removing a moulding plug to better suit the installation methods, as long as your method is still protected by the same rated plugtop fuse it had before (if it came with a standard 13amp plug) and you have made a suitable connection. If the window ever developes a fault then as long as you show the electrics were connected correctly and you have the cert's to show it was fitted installed and tested by an Electrician then they cannot remove the warranty, this is the same with many products like washers, dryers, fridges when you may need to remove the moulded plug to pass the flex through the unit top. The warranty is only void if it is found that any substandard connection or replacement plug etc was found to be a contribution to the product failure.
Thanks for the comments guys, I'll go with what I was thinking then. Moulded plugs are a nightmare and I've cut them off before in kitchen installations for integrated appliances so it must be ok to suit the installation method.
cheers
Won't bore you with our argument.
Remember your joint to the Velux cable must 'maintenance free', if it's inaccessible. Did consider replacing Velux flex with a slightly longer one, but that was ruled out by Velux. My customer decided on using the supplied flex & plug top, and fit small circular access panels.
I put visible FCU's on my wall and they are high up and look fairly crap, they are on my list of electrical jobs to rectify:-(!
Thanks in advance
Tell me you weren't considering boarding over a plug and socket?? Daz
I usually go for a round dry liner in the ceiling to side of velux and a conduit box lid on top. All connections mf supplied off lighting circuit generally.
Sent from my iPhone using Tapatalk
I ve recently wired in some velux windows, I wasn't sure about the plug top either so I gave them a ring and they said I CAN cut them off. I put S/FCU's in the sceiling next to Windows, you don't really notice them and it provides local isolation.
sam
sam
Huh! Left hand right hand.
Is there any documentation anywhere on the net that's official do to speak with regards to chopping plugs off? I often have this with customers, I say to them it's fine and some get funny.
maybe if I could show them something slightly more official it would be good,
