J
Jefferson steelflex
Hi,
Just wanted to ask just for knowledge purposes, a question regarding automatic power disconnection.
Im due to start working on a porter cabin site, one of the things they want us to do is put a system in place where for example if a kettle is switched on, the power to the cooler is switched off. This is because the max power generated by the generator is 3kw. So they don't want a scenario where the appliances exceed that. So in order to alleviate this, they want power to be switched off to other appliances when one appliance is drawing too much power.
Can anyone recommend a relay or a device?
Thanks for your help.
[automerge]1598473786[/automerge]
Just to add, I'm wiring up porter cabins to be used on site, its partially powered by 12dc battery and a 3kw generator. Will have a consumer unit and fcu connections and sockets etc. The lights will be led powered by the 12v battery.
