Discuss Electrical relays in the UK Electrical Forum area at ElectriciansForums.net
Hi,
Just wanted to ask just for knowledge purposes, a question regarding automatic power disconnection.
Im due to start working on a porter cabin site, one of the things they want us to do is put a system in place where for example if a kettle is switched on, the power to the cooler is switched off. This is because the max power generated by the generator is 3kw. So they don't want a scenario where the appliances exceed that. So in order to alleviate this, they want power to be switched off to other appliances when one appliance is drawing too much power.
Can anyone recommend a relay or a device?
Thanks for your help.
[automerge]1598473786[/automerge]
Just to add, I'm wiring up porter cabins to be used on site, its partially powered by 12dc battery and a 3kw generator. Will have a consumer unit and fcu connections and sockets etc. The lights will be led powered by the 12v battery.
You could put a changeover switch on the wall, turn 1 way for kettle other way to power cooler etc.
It’s a simple and cheep solution.
This sounds like best idea to me.
Thanks for the help guys, however site manager insisting on this for some reason, anyone have a link to a shedding device that's bs or en certified?
Ok then, they might change their mind when they see the prices!
How many appliances does this need to control?
Are the appliances hard wired or plugged in? Does it need to dynamically control the load, or just prevent more than one appliance being used at a time?
Do you know what all of the appliances will be?
The shedder itself will only switch about 1amp so relays are needed as per this diagram, this one by Hager.
[automerge]1598544492[/automerge]
A link to where you can buy them: Délesteur Hager et Polier, délesteur électrique 123elec.com - https://www.123elec.com/gamme-materiel-electrique/modules-commande-ecocompteur/delesteur.html
Reply to Electrical relays in the UK Electrical Forum area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
For power outages, my solar inverter (+battery) is able to take on the entire house load - as long as I unplug my collection of vintage kettles...
Hi There, Just wondering if anyone is aware of any devices that automatically preserve vehicle 12V battery life by breaking the circuit once the...
