M
Marlon01
I have recently had a kitchen fitted and the electric oven, cooker hob and dishwasher are all plugged into an extension lead that is lying on the floor under the counters about 3 feet away from the sink. This to me seems very wrong! These are my questions...
1. Shouldn't all these appliances have a dedicated wall socket each.
2. Shouldn't both the oven and cooker hood be isolated so they can be switched off independently.
3. If they are all using maximum power at the same time, would this not be too much power for the extension lead.
Any speedy answers would be most helpful
Marlon
ideally
depends, most would say yes, others may not agree
hopefully the fuse in the extension leads fuse should pop before it melts, however not always the case
Marlon
without more info its hard to say, from you post it sounds rough as a badgers butt, when this kitchen was fitted was there any electrical work done? Or was it left as it was? Either way, the forums probably not the best place to ask. If I were you I'd direct those 3 questions to the dude(s) who installed your kitchen?!
Me crystal balls not getting enough reception :bucktooth:
You'll know if fuse blows, if there is a fuse init .. It's not wrong as its fused at the plug top but I would never leave it like that and can say not many others would too..
Marlon
have a look at the Kw ratings and get back to us.
Marlon
Who installed the kitchen, who did the electrics, what do the certifcates say? and then talk to the installer.
Sounds like a bit of a botch job to me, but guess if it was done on the cheap then maybe not a surprise.
<<Who installed the kitchen
Sounds like a bit of a botch job to me>>
Dave the kitchen fitter, with his mate Barry the woodbutcher and wetpants (who is "part p qualified" to do the rest.
Oh, and this must be a wind up, if you are being serious, though, the person who installed it knows eff' all about electrics, or plain safety....
Yes to all. If the kitchen has recently been fitted it should have been planned properly with no extension lead in sight.
It's not against the regs and it's certainly not 'illegal', but it's not a professional job IMO.
Marlon, post up your rough location. One of our knights in shining overalls will be able to come and take a look after you get some answers from the original installer.
I typed a thanks but it seems to have disappeared. Anyway just wanted to say a massive thanks to all of you for your help in confirming that I'm not going mad. Your great comments fuelled a Mr Angry letter which I wrote last night and seems to have hit the mark! My only worry now is that the kitchen counters (including oven housing, sink etc) will all have to be removed to have access to the wall for the new wall plugs! Oh well better safe than sorry. I will keep you all posted...I may need further advice based on my next lot of findings! I'm electrically challenged and unfortunately was relying on the expertise of the electrician and builder. Hasta pronto! .....
hmm. sounds like you may need an independent assessment of the job. what's your location. one of us will be close enough to oblige,
Thanks and that's a great idea. It's in London but the trouble is I'm away on holiday for 2 weeks and all this kicked off just before I left. I'll wait and see what to the result of my complaint is and take it from there. An independent assessment sounds like such a sensible idea!
