I thought that I posted this in the DIY part of the forum but I believe I did not. I am sorry about that.
I put in a 10' x 20' metal shed about 9 years ago. It is about 200' ~ 70 meters from my house. It is on a 6" concrete pad. At the time of pouring the pad I put a conduit through the floor for the future possibility of putting electrical power into the building. I own my own 40 hp 990 JD tractor with an FEL and BH which this shed houses and use it often for many purposes. Through providential circumstances with my well and having to dig that all up I decided it would be a good time to put power to the building. I would like to put in some LED lights and a couple of outlets so I can run some tools when I need to at the shed. The best way I am thinking to do that is to put a subpanel into the building. I have calculated the distance of the wire needed to be ~300'. I want to use direct bury cable. Cu wire is pretty expensive now a days. I have had many suggest I use Al wire instead for making the run. I am planning on having 20 amps per leg for the power. Using the referenced calculator Voltage Drop Calculator | Southwire it comes up with 2 gauge on the Al wire to keep the voltage drop to a minimum. I could go with 4 gauge if I use Cu. I can get this wire from Lowe's 2-2-2-4 3E AL USE-2 RHH RHW-2 MOBILE HOME FEEDER 500 FT | Southwire which is 2-2-2-4 @ $3.87/ft. There is also 2-2-4-6 3E AL USE-2 RHH RHW-2 MOBILE HOME FEEDER 500 FT | Southwire at Lowe's which is 2-2-4-6 at $3.50/ft and they have it in stock. I am not so concerned about the price difference since it is only $141 difference. The 2-2-2-4 I have to wait to get and the 2-2-4-6 is available. My question is would the latter with the 4 gauge neutral be heavy enough gauge for the return or should I stick to the 2 gauge for the neutral?
I am looking at the following subpanel since Eaton is what I have in the house for the main panel and also an existing subpanel which I put in when we had the kitchen redone and put in central a/c in order to give us more breakers. My existing panel is a 150 amp and the sub panel is a 100 amp sub panel which is directly connected to the main panel and of course the neutral and ground are not bonded in the sub panel.
I'm looking at these two Eaton subpanels. I am not sure what the difference really is in both of them accept the price. I want to stick to the Eaton because it is always nice to be able to use the same breakers.
https://www.lowes.com/pd/Eaton-125-Amp-6-Spaces-12-Circuit-Main-Lug-Load-Center/3015036
https://www.lowes.com/pd/Eaton-125-Amp-6-Spaces-12-Circuit-Main-Lug-Load-Center/3047889
There is this one also with a little more space but I do not think I would need so many spaces but you never know and it is not a whole lot more money for it either.
https://www.lowes.com/pd/Eaton-125-Amp-8-Spaces-16-Circuit-Main-Lug-Load-Center/3014061
With any of these I could add a couple of extra circuits like a 15 amp for the lights and have 2, 20 amp outlets obviously knowing I can go max 40 amps at 120 V and 20 amps on the panel at 240 volts.
Obviously the neutral and ground will not be bonded in the subpanel and I will also be driving a ground rod for the sub panel because it is detached from the main building and a long ways away with no other connections and this is what code requires.
Thank you for your input on the wire gauge and any other thoughts you would have.
P.S. I will be digging the trench with my BH and putting it at least 24" deep (bucket is 18" wide) and even though I will be using direct bury wire I will put it into a conduit.
This is definitely one for a USA member such as @Megawatt.
Speaking from across the pond I would generally say go with copper wire unless you absolutely have to save a serious amount of money. Aluminium is more prone to fatigue breaking and you need to take special precautions to avoid galvanic corrosion (use of contact grease / noalox, etc) and the larger size for a given current carrying capacity ("ampacity") and/or voltage drop means a larger bend radius for safe installation.
The rules on grounding/earthing for the USA differ a lot from the UK so I can't really comment on that aspect other than to reinforce the point that after your incoming supply point you should keep neutral (cold) and earth (ground) separate on sub-main cables and DB, etc. I vaguely remember something about concrete buildings are supposed to have internal rebar rods grounded but I will wait for someone from the USA to give the answer on that point.
Sticking to the same brand of DB makes sense, just check the age in case they somehow have changed compatibility (probably OK, but a few big-name suppliers in the UK have made stuipd changes for no obvious reason).
Stick with number 2 and no ground rod is required. Pull a 4 wire service to your building sub panel and you are legal. I always use main lug only sub panels. No ground rod and with the loads your referring to should not be any problems
Northern NJ
United States of America
Electrifying my tractor Shed and using proper gauge wire
Robpm990,
Megawatt,
