Discuss electrode virgin??? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
brs73
hello there
i'm installing an earth electrode for a three bed house thats never had an earth!!!!
i just wanna know if i definately need a 100ma time delay rcd(100 quid?!)
i've already got a 100a main switch/63a 30ma rcd/63a 30ma rcd split wylex 17th distribution board
is it absoloutly neccesary for a rcd main switch when i'm protecting ALL circuits with the 30 ma rcds anyway.
i havent done any tests on the electrode yet but i dont wanna go all the way to the job without the right gear
any help would be very very handy
cheers
I'm only recently qualified, but as far as I'm aware, if all your circuits are protected by Rcd's, then a 100amp main switch is fine on a TT.
I'm hoping some one with more experiance will confirm.
This a bit of a grey area, as you need to ensure that the manufacturers state that the consumer unit that you are housing these RCBO's or RCD's in IS class II or of all insulated construction.
Not all state this.
Reply to electrode virgin??? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Need some advice, I have 7 static caravans to connect which need to be connected via TT 1. All the vans have a 30ma RCD main switch internally...
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
Doing a lot of EICRs at the moment and have came across what I'm sure is a common enough problem. In an off grid rural cottage I have a TT system...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
