Discuss Element question? in the UK Electrical Forum area at ElectriciansForums.net
Ross1
Morning guys,
Appliances are not my forte but I'm helping a friend. I've replaced his 1800W element that was blown. When I turn the isolator on the element in question just goes on by itself, without even turning it on at the knob. Obviously this is why the last one burned out.
Any ideas why this is happening guys.
The cooker is a zannussi and is over 12 years old.
Any help would be appreciated.
Cheers
switch/thermostat knackered. get the meter out.
Its common when elements blow that the large current welds the contacts in the stat (control knob) .. afraid it sounds like you need to replace the control stat too.
Yep its usally the oven or the most used ring. If its fan assisted then take the cover off and the element should be distorted.
I know this because I will repair my own cooker but not in my business (too much bother)
Reply to Element question? in the UK Electrical Forum area at ElectriciansForums.net
Good morning, So I’m working on an existing 3 phase solar system and the customer wants a way to use the huge mass of exported solar on their...
A friend's partner has an interesting fault, if it is a fault. She sets the shut down timer on the cooker and when the timer goes off (which in...
Hi All, My 1 and half Smeg cooker recently tripped when using the main fan oven. It was during quite a long period of cooking a roast. We reset...
Hi everyone! Im not an electrician but just a guy looking for a possible answer before I call my electricity supplier. Every month without fail...
