Hi, I recently purchased an Elu TGS173 "flip-over" saw, combination table saw and mitre saw, from an auction. Once I got it home, and after giving it a brush down, I attempted to power on the saw, which was in table saw mode/position. When attempting to press the start and stop buttons I couldn't depress the green start button. After a while I decided to change to the mitre saw position, and bingo, using the trigger on the mitre saw handle worked, the motor ran beautifully.
When in mitre saw position, I did not have to use the green and red start and stop buttons, just the trigger. I noticed a small switch near the start stop buttons when the saw table is flipped, it becomes depressed when in mitre saw position so I assumed it was some sort of bypass switch.
When in table saw position, the start stop buttons felt mushy, as if there was a physical blockage not allowing the switch to click into place. After unplugging, I removed the switch box casing to take a look. Once the lid was off, the physical switch clicked back and forward ok. I suspected a number of things causing the blockage, a piece of plastic, the neutral connection to the tables metal pole, to no avail. After ruling the physical blockages out, it left only the solenoid switch, that when depressed, was pushing back on the buttons.
In the process of trying to get everything to fit in together, I've broken a leg/connection from a diode B250C1500. This is a bridge rectifier, but is apparently being used as a half wave rectifier, as part of the No-Volt release mechanism. When looking closer at this item and learning more about it and how it's used, I noticed that the third pin had also become disconnected.
I've ordered a new B250C1500 diode (bridge rectifier), when it arrives I'd like to know how to wire it all back in. The Elu TGS173 doesn't have a wiring diagram available that I could find. I've attached some photos that show the current state. I disconnected the Earth when trying to squeeze the wires back in when I thought it was a physical issue, I know it needs to be re-attached.
I think it's pretty straight forward but the presence of the bypass switch for mitre saw operation is messing with my mind.
My main concern is the B250C1500 rectifier connections. The rectifier currently has two legs attached, (+) DC - connected to the solenoid, and (~) AC out - connected to nothing. As you can see from the photos, there is a brown wire attached via an L-shaped spade connector to a black wire. That black wire is one of the broken legs, but to which free terminal on the rectifier should it be connected? (~) AC in or (-) negative DC.
I've not found a wiring diagram for this, but I've found a similar Elu machine with a photograph of its switch box for reference on the internet here: https://static.byggahus.se/attachments/images/medium/87/87498-a4077836f76a1d2607ec714e7e0beeba.jpg
- but this model doesn't seem to have the mitre saw bypass switch.
Any help gladfully accepted.
----- Edit ----
I should have mentioned, it is a 240V, single phase machine.
So, I've been able to locate a wiring diagram for the machine in question. I've attached it to this post, in case any other woodworker has the same problem as I have had.
Could you try again posting the wiring diagram - use the picture icon, or copy and paste.
I think the purpose of the bridge rectifier is to provide motor braking when the stop button is pressed, by momentarily feeding dc to the motor windings.
I imagine the incoming ac (~) connections to the rectifier would be mains N to one lead and a normally open connection to mains L from the switch mechanism that becomes live briefly when stop is pressed.
Then at least one, if not both, of the DC + & - rectifier outputs would go to a/the motor winding creating a stationary magnetic field that induces eddy currents in the rotor which provides braking.
The wiring diagram might help!
The circuitry you are dealing with is essential for safety of the machine, so it's important to restore it to its original configuration. The switch you describe is likely a no-volt release switch which has a solenoid that needs to be fed with power in order to operate it. Possibly nothing wrong with it other than an interlock switch somewhere was not feeding power to it?
OK, here's another attempt at attaching the wiring diagram. Ah OK inserting as an image is better than attaching!
I don't believe this machine has braking, but I could be wrong about that. I think the rectifier is to keep a pulse of energy to the solenoid so it doesn't release it's position, which would mean turning the switch to the OFF position. But see what you think from the diagram.
You are right, no braking here I don't think.
The rectifier supplies DC to the solenoid and when you press the run button the solenoid should hold the swich on.
I see only 3 of the bridge rectifier connections are used, the -ve is not connected.
Apologies - At the time of writing this I had in mind the photo you linked to was actually your machine, so the comments below relate to that misunderstanding!
In your first post you refer to "the photo's", but they are not attached - might be useful to do that.!
The + side of the rectifier you say is still connected to the solenoid as it should be.
The ac sides of the rectifier should each be connected, one side (the right in the diagram) goes to two places, namely the other solenoid red wire and to the brown feed to the motor (somewhere - could that be the tag behind the front left blue wire in your photo?)
The other ac side of the rectifier should ultimately go to the blue wire of the motor, presumably via one of the tags on the switch.
If you have a multimeter you should be able to continuity test which tags on the switch relate to which contact on the circuit diagram!
I attached the photos twice but they didn't upload, but I'll use the "Insert Image" feature as it worked for the wiring diagram.
Anyway, here are the photos:
20260916_104309.jpg20260918_122116.jpg20260918_122107.jpg20260918_122055.jpg20260918_122041.jpg20260918_112732.jpg20260918_112707.jpg20260918_112639.jpg20260918_112628.jpg20260918_112255.jpg20260918_112248.jpg20260918_112218.jpg
In the attached pic is presumably the broken off lead of the diode from the remaining (ac)~ pin?
You presumably know which way round the currently disconnected brown and blue motor push on connectors go!
Essentially one diode (ac) pin goes to the airborne brown connector and the other diode (ac) pin goes to the airborne blue connector (doesn't matter which way round!)
I think you have everything you need now you have the wiring diagram!
I didn't. That was the point of this thread really. But since writing the initial thread I found the wiring diagram and so I now think I know which way round it will all go back together. I'm waiting for the new rectifier to arrive from ebay, however it's not yet been dispatched two or three days after ordering!
I suppose any advice on testing I get it all right before turning the power on would be useful.
The forum is not supposed to give step by step guidance so as not to encourage guests to undertake work outside their level of competence.
You've got this far with the project, have the information needed, you know tests are prudent before powering up, so I'm sure you'll use common sense to check continuity of earthing and correct connection of the components in the safety circuits.
E.g. continuity between things that should be connected, and similarly no continuity across power lines or to E, other than the anticipated resistance of components you know to be in circuit. This is probably the best you can do, unless you have access to a PAT/EET tester or equipment that can measure insulation resistance at high voltage.
This is not ideal, but I'm sure you know that!
