Today I've been working with an old emergency bulkhead with 26W 2D 4 pin, and 6W florescent tube.
When I replaced the 2D bulb, only a faint light could be seen coming from it. I assumed because there had been some physical damage to the fitting, that a component inside was bad.
As I went to dismantle the unit (ready for replacement), I removed the starter module, and immediately the 2D bulb sprung into life. I put the starter back in, and the 2D bulb returned to almost lifeless. Took the starter out again, and on comes the 2D bulb.
Are these lights designed to not work if the starter is bad or if the florescent bulb is missing, or something else?
P.S. We don't need the emergency backup to work anymore, and I'm happy to leave as is. Just curious about why the 2D bulb works when the starter is removed.
Any clues on what was happening?
yeah .you had taken the starter out because its like a key stating a engine it call igniting the gas.
I will try that when bending over with a flame .
Sure, I know what a starter does, but 2D bulbs have an internal ballast. Yes?
The starter is for the florescent tube, but doesn't explain why suddenly the 2D bulb started working when I disconnected the starter.
So, any idea?
No 2D bulbs don't have an internal ballast, you usually see them with high frequency ballasts these days but the traditional ballast and starter approach used to be common.
The starter will almost certainly be for the 2D lamp, the emergency side would normally use an electronic ballast as the battery wouldn't be able to start the tube via a starter
Okay... but logically this doesn't make sense to what I'm looking at, which is no starter and working 2D lamp.
I'll upload a pic to show you. The circular hole is where I removed the starter from. Clearly, the 2D bulb is lit.
Explanation?
Scotland
Emergency Bulkhead Operation?
Lighting Forum
Thread Tags
Tags Tags
emergency
OttoF,
Dangerous Brian,
