Discuss Emergency lights or standard in the UK Electrical Forum area at ElectriciansForums.net
Fed via photocell too
The supply to the battery pack should be from the PL. When the test switch is in the test position then power is cut fooling the light into thinking a loss of power has occurred and the light should switch to battery back up. When not in the test position the batteries will charge indicated by, usually, a green led being lit.
The supply to the lamp, via the contactor and photo cell should be is the switched live and should go in the appropriate terminals on the light.
Thanks understand a bit more now, I’m back tomorrow so will check the wiring cheers for your help
Go back to basics initially and check your incoming supply as per #22 it wouldn't be the first time a contactor ditches the PL, if the charge indication goes off when the contactor is off it is connected incorrectly but not necessarily at the fitting. If all this is okay you can probably assume the fitting/s are duff.
Right this is what they have now, I’ll do a drawing of what I think it should be and you guys can correct me if I’m wrong? Or any other solutions? Or if anyway has a drawing would be must appreciated haven’t really touched key switches I know it’s a normal switch basically or contactors
I would be happy to post a wiring diagram, would this fall foul of no step by step instructions rule?
Strima
The switched live side feeds direct to the led geartray 230v via the pins and the emergency/perm side go through the module witch should have a built in battery witch would power a second set of led,s on the geartray via the battery in the event of a power outage
There are multiple ways of doing it, depending on exactly what function you want from the manual on / off switch and the photocell override switch.
but this is one way it could be achieved.
Strima
That just seems like a lot of faff...
To be fair all the 2D EM fittings I've dealt with were solely 2D with no additional LED lamps hence my comment.
Reply to Emergency lights or standard in the UK Electrical Forum area at ElectriciansForums.net
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi folks, Can anyone recommend a reliable brand for emergency lighting bulkheads please? I have a job coming up to replace 30 odd units. I have...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
I've been asked by a client to 'mask off' the green LED charging indictor lamps within several emergency lights fitted within bedrooms on a...
