Most...but not all are usually dual operation, have L, N and SWL.....If the need to be non Maintained, then there is not connection to SWL, if they need to be maintained, then SWL can be switched from pir, light switch or just linked to L as a solo fitting.
With any em fitting grid or not.....you have the choice of maintained or not...its down to you how you wire the installation
