Discuss Emergency spots, connection advice in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
A client has kindly changed their mind on the emergency light they are using. They want to me to install these
https://www.channelsafety.co.uk/eme...ed-downlight-products/glade-1w-led-downlight/
I’ve used these quite a lot and I’m most casss they are a good job, I would usually install beside a spot light or similar so I can access/install a connection box. In this case I cannot do that as cables already installed. The cut out for these is 38mm, does anyone know or have any advice on a small junction box or connector that would be compliant to allow me to connect these?
What cables/flex are supplying this fitting eg 2 x 3 core & e etc. also is the fitting pre-wired. Saying that a lot of fittings seem to be designed to take one cable. We use a lot of CP Electronics plug-in boxes which is fine above a suspended ceiling but you with an MF ceiling you have to plan a bit ahead. I take it that the ceiling is now plasterboarded and the original fitting was either surface or had a larger cut-out.
Hi all,
The way I did it was to cut a short piece of plastic conduit with male adapters on each end and stuffing glands in the adapters.Make the joint with crimps or wagos,feed inside conduit and tighten the stuffing glands.Push the short conduit thro the hole,followed by the em light.
Regards S
Reply to Emergency spots, connection advice in the UK Electrical Forum area at ElectriciansForums.net
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
Hey guys, looking for a bit of advise on the installation of an outside light. I plan on chasing out the plasterboard and running a cable from a...
