Discuss Energenie TRV heads not following Nest. in the Central Heating Systems area at ElectriciansForums.net
Seems intermittent, some times as it should when the Nest thermostat changes temperature the 4 linked TRV heads change with it, but some times they don't alter, not an issue when temperature is dropped but it is an issue when temperature is raised as the pump is sucking on closed valves.
Easy cure is to program independently, but that rather defeats the whole idea.
Nest is not my field of expertise , does it all rely on Wifi signal from router ?
Thinking monitor for weaknesses , wet coats hung up ,or
sources of interference.
(Recently found out how naf my wifi was with my phone dropping out -audio streams wifi - with Blue tooth speaker connected ..
Or maybe just my phone is xxxx ! )
The wifi router is under the wall thermostat just 3 foot below it, the Energenie hub is sitting on the router, all three about centre of the house.
To alter on the phone it all works A1, turn up the wall thermostat and all the linked TRV heads auto change to same temperature.
However change with the PC or with a set schedule, and it's hit and miss, some times they follow, and some times they don't. The problem is if I turn up the temperature then the boiler is running, but TRV heads have not opened so boiler starts to cycle and pump may start to cavitate as TRV heads are closed.
So at the moment the TRV heads are simply set to same schedule as Nest or a higher temperature to Nest, never lower. So pump will not cavitate and Boiler cycling kept to minimum.
So my £45 Energenie TRV heads are not doing as good as a job as my eQ-3 programmable heads which only cost £15 each with bluetooth, but I find I don't use bluetooth once set up, I walk into room and press the comfort/Eco button which swaps from 17°C to 21°C until next schedule change.
So sitting in my bedroom at moment, eQ-3 TRV head set to 21°C the thermometer next to me says 21.3°C and old unused programmable thermostat other side of laptop shows 21°C so the cheap TRV is doing a really good job.
Rest of house target and current within 2°C of each other, and only shows whole numbers so likely closer.
Reply to Energenie TRV heads not following Nest. in the Central Heating Systems area at ElectriciansForums.net
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi there, I've had 4 plumbers & 1 electrician look at my problem (seemingly without dedicating too much time unfortunately), spending more than...
10K
Hi all in the forum, I have a 6 radiator Y plan system with pump over run. There are 5 TRV's on the rads and the living room radiator is open at...
