Discuss Extending the broadband from the Openreach 5C master socket in the UK Electrical Forum area at ElectriciansForums.net
Hello. I have a BT openreach master socket (new type with built in filter) and I want to extend the broadband about 3m away and hide the cable in the wall.
How can I connect the cable from the FILTERED part of the master socket as I do not want to use a filter at the new point? I want to use a basic IJ11 modular socket for the new router point.
Run a CAT5/6 cable with RJ45 plugs on each end.
Apparently the red AB socket on the rear of the faceplate is UNFILTERED
Correct. It is telephones which need the filtering, not the VDSL signal.
Don't think of it like a high/low pass filter, like you would find in a speaker system (tweeter/woofer), that's not how it works. The filters don't separate things into two distinct sets of signals.
Reply to Extending the broadband from the Openreach 5C master socket in the UK Electrical Forum area at ElectriciansForums.net
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Hi the other day I opened the socket just to find out that 2 neutral wires were damaged with visible copper so I decided to cut them short and put...
I am wiring a garden room which will be a home office, customer wants wired ethernet points and wifi down there from the house router Its too far...
Hi, I would like to add a new socket in the bedroom. Current room configuration: 3 existing sockets - wiring coming from the bottom (under the...
Hi All, This might be a bit of an odd question, I would really appreciate your thoughts. I am trying to up-date my mum's home, before putting it...
