Discuss Extending wiring into loft in the DIY Electrical Advice area at ElectriciansForums.net
C
charlie-g-m
Hi all,
I have a few questions regarding the loft conversion I’m doing at the moment:
  1. Is it okay to extend the first floor lighting circuit up into the loft? It’s separate from the downstairs circuit and currently has 5 lamps on it. It would be extended by five, two sets of recessed halogens x 3, a stair light and two cupboard lights. It’s a small Edwardian terraced house to give you an idea of the wiring length required.
  2. Is it also okay to extend the ring main into the loft or should it go on a separate circuit? There are 9 double sockets plus one single spur on the ground floor, and 4 doubles and two singles plus a combi connection on the first floor. The loft would require 4 more doubles plus two single sockets.
  3. My final question (for now!): how much work can I legitimately do before I emply an electrician to complete the Part P? Can I lay wires, fix boxes, etc.?
Cheers
Charlie
PS I have no electrical qualifications
you can extend the 2 circuits. it is not notifiable under part pee as long as not in a special location ( bath,shower room).
if is your own place you can do whatever you like.
if thats a job for someone then get an electrician to do it, especially if you have no experience with electrics. theres lots of costly and deadly mistakes to be made...
So, a loft conversion..... what do building control say about smoke and heat alarms?
Reply to Extending wiring into loft in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
