Discuss External PIR (LED) in the UK Electrical Forum area at ElectriciansForums.net
Hi guys and girls
I'm doing some work on a old cottage and the clients want an old outside PIR light replacing.
The circuit is on the lighting circuit but I can't see where the cable enters the property I can only see where it cones out the wall from on the outside. There is no FCU on the inside so I think it may go in in the ceiling/floor void somewhere.
The client wants minimal disruption so i'm inclined to put an external FCU where the cables comes out the wall but not sure this is ideal from a security point of view. Was just wondering if anyone has any other solutions as an alternative?
Thanks in advance :)
if it's on the lighting circuit, it's already fused (or MCB) at 5A or 6A, so the only advantage of a FCU would be for isolation,otherwise it's not required. just swap fitting for a LED unit. if the new fitting has tails alredy fitted, you will need a wiska box. Screwfix sell LED fittings thay you wire directly into.
Ah thanks guys, i had it in my head an FCU is required if a cable goes from inside to outside, not sure where I got that from then. Unless I was mixing it up with downrating.
I'd still like a form of isolation on it but if its ok to not have one on there then I might just do the straight replacement then.
as it'salikeforlike replacement, there'sno need to alter the circuitry, unless , of course, you find it's not suitable/dangerous/ or faulty.
Reply to External PIR (LED) in the UK Electrical Forum area at ElectriciansForums.net
I am installing some driveway lights. The customer wants to be able to switch them on from t he house, but also have a PIR at the driveway...
I have a Security Light on my patio and until recently it worked fine. It stopped working and I couldn't decide if it was the LED Floodlight or...
Hi all, Thank you in advance... So I had an electrician put in some FCUs on spurs to a couple of outside lights.. this one was in readiness to...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
