I didn't, I moved away before I could. I've just seen the house from the outside. It's a big impressive building but I could imagine it being awkward - especially as its split up into apartments.
Big ol house in the middle of a new build estate.
My memory ain’t what it used to be.
site visit today, and the upstairs bath is actually just a shower. And the ceiling is so high I think I can get away with a 230v
The lower floor bathroom still may be a problem.
The room above this is a kitchen with laminated flooring. I’ll have to get that lifted to see which way the boards are running, and in turn which way the joists are. I’m hoping towards the window there so I can put in a ceiling fan and duct to outside.
There is a room with the carpet up, and the joists are running the way I want, but no guarantee being the same in an old building.
Turned over the hall carpet, and those boards are running diagonally... so no help there.
Customer also wants an electric point for a towel rail on the wall to the left of the photo. Drilling through a 3ft wall into a bedroom, then either chase right up to ceiling, or surface trunking on top of skirting to nearest socket.
core it out, man. and don't be put off .a 230V fan in zone 1 is compliant as long as it' IP4x.
Strong magnet on that ceiling might help find joist direction?
The other thing to remember if you want to run a duct in between the ceiling and floor above is that in a building like that there will probably be deafening or deadening or what ever folks like to call it. Ie. another layer of boards with rubble and plaster on top. Awful stuff!
@littlespark Why does the fan need to be 12v? There are plenty of suitable 230v fans for the job.
What do you install when someone wants an electric shower, cause they are 230v as well?
Why do they manufacture 12v fans?
I had in my head, bathtub with a fan within touching distance, never mind in a specific zone... and as tel rightly mentions... fan with the correct IP rating.
Moot point now as it’s way higher than I thought.
Joists in an old building probably have herringbone strutting between the joist.
I’ll find out after I get the boards up.
Back at this house today actually doing some work.
Customer had opened up a hatch on his stairwell and come across all this..... redundant (I hope!)
Yeh, it’s redundant. And there’s no copper in the busbar chamber either.... been robbed already.
when were phases L1, L2 and L3 ever marked as ph A, ph B and ph C? That’s what all the labels say on this.
What components do you need for the rigid ducting on a 4" cooker hood usually ?
Is that the best type of grille
What do you need to attach the rigid pipe to the fan and the grille ?
On the core drills , do you remove the pilot bit during drilling ?
Cheers
After starting the hole, take the pilot drill out and use the hole drilled to guide the core, but make sure you keep it straight so not to introduce a bend in the hole, also always use the side handle on the drill to ensure it does not break your wrist if it gets stuck due to bad alignment, rigid pipe and grill/fan should match size, I use the stainless steel outside grills from TLC: 6 Inch Stainless Steel Round Cowl c/w Internal Louvre & Mesh | Aidelle_Airflow (52644601) - https://www.tlc-direct.co.uk/Products/ADRC6SS.html, the last fan I installed was one of the Icon range that opens and close's automatically, no need for a back draft grill: Airflow Aidelle Icon Extractor Fans - https://www.tlc-direct.co.uk/Main_Index/Ventilation_Index/Aidelle_Icon_Fans/index.html. Sorry went off track a bit with extract fans instead of cooker hood extract, but still useful information I think. 🤔
Found the 4" : 4 Inch (100mm) Stainless Steel Round Cowl c/w Internal Louvre & Mesh | Aidelle_Airflow (52644501) - https://www.tlc-direct.co.uk/Products/ADRC4SS.html
Ok thanks for all that
So basically once the diamond bit bites you remove the pilot ? Is that it ?
Also seen something about driving pilot goes to reduce dust but didn't quite get that idea ?
