S
sparkyb2
hi there boys , i want to install a extractor fan in my bathroom to work whilst the bathroom light is switched on, do i just loop off my bathroom light or do i need a live from my switch and a neutral from the light fitting or the easiest way to get this fan working.
well if you want it to work when the light is on, come from the switched live from the light and neutral at the light :)
I will not start stating part p requirements and regs at you (im sure others will do that)
ok just looked earlier at the wiring and there are 2 twin and earths at the bathroom light pull switch and 1 at the light and the switch has 2 reds joined together and a black in 1 terminal and another black in the other terminal is this wiring correct
OMG.....are you serious? Don't talk about reds and blacks....in a switch or light fitting colours have diminished meaning. Basically, to wire a fan in the way you described, you need a switched live, permanent live and neutral to the fan. The switched live just tells the fan to come on, but it needs the permanent live to run on for a while after the light has been switched off.
love to open the window if there was 1 that is y i want an extractor fan in the bathroom
Ha you defo need a fan in that situation. Advice.......don't get a cheapo fan, spend a decent amount on a decent one. The cheapo ones don't shift much air and also tend not to last all that long....plus end up being noisy after a few months of use.
ok thanks boys so got a spur unit for the fan and a fan in the ceiling vented to an outside wall so need a neutral from the light and a permanent live from the ceiling switch will that get me fan working with light switched on.
