I am losing the plot with this. If it's a ducted, in-line fan, or any other fan for that matter, who exactly is going to need to isolate it??? If it's a sparky who has been called in to look at it, then he will make sure its properly isolated before he/she looks at it, who else should be needing to work on it?? They are all class 2 anyway.
Habit and handy. Although strictly speaking ive never believed they are required by 7671, manuf instructions may ask for one but im unsure if they would ask for local. Although nearly all ask for a 3A fuse. I used to fit decent fans that didnt require them.
As for a fused spur for isolation, remove the fuse, seems its deemed good enough for isolation with a fuseboard with removable fuses, also MK fused spurs can be paddlocked with the fuse carrier out, unsure if that would be DP but you have always got the MS!
This is how I would install isolation for timer over run fans , I personally install 3 pole isolators , so as the fan can be isolated leaving the lights still in use , The fused spur controlling the light and fan with a 3 A fuse would isolate the live feeds to the fan , and fuse can be removed ,,
It's a switch. Too high for compliance with building regs. 450 - 1200. Got pulled by Warwick BI. Wouldn't listen to my opinion that above door made sense
Haha BCs making it up as they go. if you are installing non lockable isolation it should be under the control of the person working on the equipment so it could be on the ceiling. its not a functional switch and using it as such would break building regs anyway.
Quite wozz but they are empire building round here. Didn't bat an eyelid at the plumbers notching however. Think they just hate us lot.
Not too sure about building regs? but an isolator can be used for functional switching (BGB P149) .....
I agree it was more from the point of veiw of a overun fan being fitted and installing a function switch to turn it off, pointless the isolator is there for isolating.
