awkward one.. situ. is the room contains a sealed shower unit and toilet. shower cubicle is one of those fancy things, all enclosed with it's own fan in the top. my thoughts were to duct this the 4" up to the ceiling and out through the soffit and if the builtin fan was not powerful enough, to add an in line fan in the attic. the builder says that building regs. stipulate that the fan has to ventilate the toilet as well, so needs to be in the wall. is he right? because outside access is not possible due to fragile conservatiory roof. if it makes any difference, the room has an opening window. this could, at a push, give access to reach through and fit grille. your thoughts please, gentlemen.
