Discuss Fans and wires in the UK Electrical Forum area at ElectriciansForums.net
the pict
Mentor
Why do fan and speed controller manufacturers use use U, Z , K or UZ sometimes the fan and contoller have different letters instead of harmonizing fan to controller, just asking never thought about it until a guy asked,
funny the things you just accept and just go by the diagram(s)
P
In single-phase induction motors, U1-U2 signifies the main winding and Z1-Z2 the auxiliary (starting or capacitor) winding. Where only three wires are brought out, e.g. for single-direction only, U is main, Z is auxiliary and UZ is the common terminal i.e. the other end of both U and Z. Similarly for reversible PSC motors with two identical windings. K terminals connect to thermal protectors, so where the cutout is in the motor main circuit instead of a control circuit, UZ might go through the cutout and become K. Controllers might have L1, L2 etc for uncontrolled and controlled line, it's up to the manufacturer whether to put the same markings on the outputs as on the motor windings and risk them not matching in some pairings of products.
I had to read that a few times with the conclusion I know sod all about motors, so I need to get a book "electric motors for dummies" if it exists
Pict
Nothing to 'em. Just a long bit of wire wrapped around a lump of iron with a spinny bit in the middle. I'm sure you know more than the expert who, when confronted with terminals A1, B1, C1, A2, B2 and C2 on the motor and exactly the same six terminals on the starter, decided he knew a better way to connect them together and produced a lot of smoke.
As it happens I have motor woes today but of a different kind. My Y-YY and Z-ZZ are AOK but my A-AA is not happy.
When I was doing fridge work many years ago most little multi fit motors go acw and van stock was 7,10,25, 34 watt on an odd occasion you would get a CW as OEM which blew air the wrong way if you fitted one of the ACW , so either bend the blades which was ever so last resort or back to HRP and hope the could help which was never, till and old hand behind me in the queue asked if I had a 7mm socket yes I said, ok said the old owl follow me he then showed me how to make it go in reverse by turning the stator, felt a right numpty cos as you say if you think about it you probably knew the solution
Reply to Fans and wires in the UK Electrical Forum area at ElectriciansForums.net
Hello, I currently have two switches in my bathroom. One controls the lights above the sink and the other controls a light above the toilet and...
Hey everyone. Got a head scratcher for wiring a fan with a speed control with a run on timer on site today. I, and two spark could not get it...
I have a ceiling fan which currently has a remote control for fan speed and dimming the attached lights. We're currently doing some works in the...
I have a pressure washer that I got as part of "a good deal", actually an exceedingly good deal as I later found out. I've had it a while, I guess...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
