Discuss Faulty Aqualisa shower in the UK Electrical Forum area at ElectriciansForums.net
A
aqualisa
Hi , Any ideas why my electric aqualisa shower stopped working pls? If I go up to the loft and flick the white button on and off just once the shower works for a little while. Then stops again . Thanks . A
What have you got with a white button in the loft? Is this Shower an instantaneous type?
[QUOTE="aqualisa, post: 1557215, member: 120615"
The water is heated up separately . The shower is power shower only to create pressure not to heat the water , Thx
What is the white button? is it on the pump? could be a reset button, if yes the your pump has a fault, time to consult a Plumber or Electrician, post your location a Member may be able to help you out.
The white button stands on its own next to the covered electric boxes.
Assuming you have the digital pump in the loft, some of those were a faulty batch and are replaced free of charge if you have a service contract. Mine behaved just like yours, and the man came out, Chris from Aqualisa, top bloke btw, and interrogated it on his laptop, saw it had over 1000 restarts or something, and just fitted a new pump and all was well.
If you have the push button in the shower with a blue ring led round it, is this dim? If so, it's worth taking the button assembly apart and cleaning it and the contacts on the push-fit cable connector. If the led is brighter thereafter and the shower works ok, that's a simple fix.
[QUOTE="aqualisa, post: 1557224, member: 120615
Pls see pics taken in the loft. Thx
HI, It is an old shower so not covered by Aqualisa any more at all. PLs see pics taken in the loft. On and off push button switch in the shower itself lits up works ok . THanks
OK, the white switch in the loft is the isolator for the pump. Mine was in the bedroom next to the shower room. Switching it on and off cleared the problem for a short while. I think your pump is faulty, frankly...
First thing is to have the electrical connections checked .
Second , how old is the pump?
Hi, The pump is nearer to 10 years old . Pls see the pics taken in the loft. If i flick the white switch on and off once then the shower works for a short while. After that it stops working again . Thx
Thank you Pirate
that's pirate, youse asking. he probably ended up with a choice of a glass of grog or a walk the plank.
Have spoken to Aqua Lisa in the past about an intermittent problem, they actually told me to turn the unit off completely for 30-40 mins which has worked for me previously on 2 occasions.
Hi, How long did your shower work after you have turned it off for 40 minutes please? thanks
Not personally my shower, but both incidents were to do with the controls within the shower not working.
Haven't heard anything back from either client so assume all is well!
Reply to Faulty Aqualisa shower in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Hi all, A few months ago we had a Triton Martinique 8.5kw shower installed. We've noticed that the temperature seemed quite low. Its what I'd...
hi ive got an unused isolator in my airing cupboard that use to run a shower. no longer have has have combi boiler feeding a new shower. the...
Hi, We are renting and have a electric shower downstairs (extension) - a 9.5kW Triton T80Z fast-fit electric shower as well as a combi boiler...
4K
Hi, I am changing the electric shower in a bathroom refurbishment (my own) and just wanted to ask about the mcb rating. The existing shower was...
