I
suspect that there actually is.
I don't know if it helps but here's another couple of format forms that might clarify the one you are looking at.
This is the Napit version... the section on the left is for what's supplying it, as we discussed. The section on the right is for "this end" of it; I think Zd should actually say Zdb (as Zd means fault current of first fault in an IT earthing system) and Ipf should have the associated prospective fault current for the distribution circuit. I'm not overly impressed with this bit on the form, it's not laid out clearly at all!
Here's the Electraform version which is the easiest to understand of all of them in my opinion. I miss using this!
I can't tell which form you have (?NICEIC) but I suspect it is in two parts like these two above.
