Discuss Finding replacement LED driver in the UK Electrical Forum area at ElectriciansForums.net
I have in LED light which has stopped working. It's well-travelled, made in China, bought in Azerbaijan and installed in the UK.
I assume the problem is with the LED driver, picture included. Made by Guo Xin, model GX-F36x1W for which an internet search reveals...nothing!
So how do I find a replacement for this to avoid trashing the (quite expensive) light fitting?
The input voltage is 185-265Vac and output 24-100Vdc at 260mA. The stated load is 8-36W which doesn't quite stack up with the output voltage x current!
as above, but the voltage range of the driver is critical. the replacement must be capable of outputting 24V - 100V. anything less than 100V and the LEDs will probably not work. had exactly same problem , only in my case it was 90V top end. a 60V driver just got a brief flicker from the LEDs.
It is a waste of time and money to replace something that turns out to not be faulty. Why don't you do some tests with a multimeter to establish where the fault is?
Reply to Finding replacement LED driver in the UK Electrical Forum area at ElectriciansForums.net
Hey folks, i work for a relatively small company, but we are doing some big jobs. And right our headache is taking over outdoor lighting...
Hi all, No electronic knowledge here. The plug/transformer of a led lightstring is fried. Now I am trying to find a replacement on Aliexpress...
Hi guys - I need to replace an LED driver for one of my downlights. I know how to make sure the bulb is compatible with the driver, but as I...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
Hi Forum people. First time post here. I have a pair of semi flush fittings that are currently 10 Halogen capsules per fitting. I want to...
