A
Adam Smith
Hello all,
Just been to look at a fire damaged light fitting in a shop. A component inside the fitting had over heated and melted through the diffuser and started a fire. I have found the problem was this little critter:
Obviously this one is from another fitting that was fine. The burned out one I found on the floor covered in melted plastic! I imagine that it is some sort of starter or choke? It was connected between L and N at the terminal block.
In every light fitting these are just left resting on the plastic diffuser which is what caused it to melt.
So on to my question. I was thinking of fixing a steel conduit saddle to the metal case and sliding the tube in to it so it is suspended off the plastic and on to something that will cope a little better with dissipating the heat. Do you think this will be an adequate solution?
Oh and checked over the installation and board... All looks fine there.
Many thanks
Many thanks
