A
AmateurRamen
*I'm still researching but any points in the right direction will help greatly.
I have a project using three
Surelite™ Ballast - 10-1180 | BuyUltraviolet - https://www.buyultraviolet.com/ballast-120-277v-50/60hz-2-lamp-10-1180
I need power supplies to accommodate each ballast efficiently.
I also need a lid cutoff switch for the circuit and a master power button.
1) What would be my best option for US power adapters.
2) Where can I find and purchase good DIY electrical components suited for these needs (cutoff, master power button, power adapter)?
3) Will any acrylic plexiglass of reasonable thickness protect from UVC contact?
Thank you for any help.
Ballast: 120–277v AC 50/60Hz 2 Lamp GPH843, G36T8 or PLL36w
Running two UVC lamps each.Surelite™ Ballast - 10-1180 | BuyUltraviolet - https://www.buyultraviolet.com/ballast-120-277v-50/60hz-2-lamp-10-1180
