Delta
Hello,
I've got a practical exam on thrusday and need some guidance on a part of it.
I've got a ring final circuit consisting of 4 twin sockets with a fused switched connection unit to be connected as a spur to supply a pre-wired tubular heater.
As I've not been given any details of the heater I'm not sure what size conductor I'm going to need.
Thanks in advance,
Tim
It was 4mm CSA singles in plastic conduit when i did mine but it was also run radially off the ditribution board as a seperate circuit and not spurred off the ring.
I would enquire as to the rating of the water heater, ours was 3 kW.
We have a separate 3Kw immersion heater circuit to put in aswell, which I would say needs a 16A type B breaker and 2.5mm FTE cable.Would I be correct in saying that?
