Evening all
Is anyone fitting surge as standard in domestic property’s?
We are based down in Dorset which has 3 different flash density’s!!
So I always base is on worse case with most of our stuff being in urban areas and always unable to confirm length of supply cable! My calc is usually;
Urban 850/(1x0.50) = 1700 No SPD
Rural 85/(1X0.50) = 170 SPD
Thoughts?
Hi - I don’t do that many domestic boards but I’ve been pricing SPD in now. I have recently fitted 3 Wylex flex S boards (NM1206FLEXS with 12 ways left after iso and SPD). These come prefitted with SPD and cabling and are nice :) .
What's the difference in cost to a non factory fitted spd unit.
I've been fitting the Hager version with pre-wired SPD, good quality unit once you tidy up the wiring to the SPD and neutral bars! Customer requested dual RCD as it was the cheaper option but usually I would try and go for full rcbo.
United Kingdom
United Kingdom
Fitting SPD as standard
TJC1,
Wilko,
