Discuss Fitting SPD as standard in the UK Electrical Forum area at ElectriciansForums.net
TJC1
Evening all
Is anyone fitting surge as standard in domestic property’s?
We are based down in Dorset which has 3 different flash density’s!!
So I always base is on worse case with most of our stuff being in urban areas and always unable to confirm length of supply cable! My calc is usually;
Urban 850/(1x0.50) = 1700 No SPD
Rural 85/(1X0.50) = 170 SPD
Thoughts?
Hi - I don’t do that many domestic boards but I’ve been pricing SPD in now. I have recently fitted 3 Wylex flex S boards (NM1206FLEXS with 12 ways left after iso and SPD). These come prefitted with SPD and cabling and are nice :) .
What's the difference in cost to a non factory fitted spd unit.
I've been fitting the Hager version with pre-wired SPD, good quality unit once you tidy up the wiring to the SPD and neutral bars! Customer requested dual RCD as it was the cheaper option but usually I would try and go for full rcbo.
Those little ID stickers fit under the plastic flaps on the mcbs then you can put further info on the strip sticker.
Reply to Fitting SPD as standard in the UK Electrical Forum area at ElectriciansForums.net
Someone asked about abbreviations used here. So I tried to copy a list I made elsewhere: A/C Air Conditioning AC Alternating Current ACB...
5K
Hi I am a sparks from the 15th Ed, did 16, 17 and last year 18th. I am out of practice though as have been office based for 12+ years in a...
We're currently recruiting for an Electrician to join our Homeworks team on a full time, permanent contract. For more information and to apply...
ElectriciansOnCall are a Kent's premier and most accredited electrical contractor covering all CT and ME postcode areas. From changing a faulty...
