Discuss Flat bits, what do you recommend? in the Electrical Tools and Products area at ElectriciansForums.net
polo1
I’ve tended to use Irwin flat bits in the past, but I’m finding they are loosing their cutting edge really quickly.
Anyone recommend an alternative which lasts more than a couple of holes in softwood?
I'll second the Bosch @Leesparkykent is recommending with the caveat, I've only got one. I've not had to replace any others yet as they don't get used that much, but they'll be getting replaced with the Bosch.
It seems to cut so much better than the others I have. I can't remember what they are but I've not scrimped and gone cheap on any of my gear.
I use these bits only .
Cheers SC. I realise the Irwin bits are not that costly, but for something that “appears” to be well made, I’m just finding that that they are blunt in the blink of an eye!
Happy to spend more for something more durable. I too believe to buy the best quality tools you can afford, but for what is a disposable purchase, are you better buying cheap & often?????
As above I got myself some Irwin Stubby Auger bits and can't fault them, find they go through joists very well and also as they are not so long it means you have a bit more room to get bigger drills in the space you are working. paid around £20 for a set of 6 back last year. Not a fan of flat bits anymore, and doubt id go back having used the auger bits.
by cheap ,pay twice, they say stated use in them since they first came out .
i use Irwin also and Vermont American, they are easily resharpened if needed and a little tip If you are drilling soft woods a lot they tend to get a bit gummy and dull quicker.
spray them with a good silicone spray lube. they will stay cleaner and hold an edge a lot longer.
It really depends on the type of work you do. For working on older properties I use these Flat Wood Bit Set 6Pcs - https://www.NoLinkingToThis/p/flat-wood-bit-set-6pcs/18593 not because they are good (they are good enough though) but because for the price it really doesn't matter if you hit a nail. Have to buy a 16mm bit seperately though
Haven’t found anything that is as good as the Bosch self cut ones myself.
I’ve got the dewalt extreme and the armeg wood beaver too but they don’t get a look in.
Sam
Thanks for all the suggestions/recommendations folks, looks like I’ll give the Bosch ones a try.
I’ve used auger bits in the past, but on a couple of occasions nearly broke my wrist when the jammed!
The quad type bits the me and Buzz linked to are not like a traditional spiralled auger bit, more like a spade bit on steroids. They remove sufficient material so that they don't jam.
missing one vital point in all this the bits are only as good as the machine driving them, so if the drill or impact driver is not upto much then you can have the best drill bit ever invented, but it will perform poorly.
Very true. I've blessed myself with a new Milwaukee fuel combi recently and it's eating joists for breakfast.
Hello All,
I have read good things about these `Armeg Wood Beaver` 4 flute drill bits:
Armeg Wood Beaver Drill Bit 25mm - https://www.NoLinkingToThis/p/armeg-wood-beaver-drill-bit-25mm/40712#product_additional_details_container
I read that although they are more expensive than even good quality Flatbits - `they cut through joists like going through butter` and apparently last much longer `in normal use`.
I see that they have a 1/4" Hex shank which would be useful for quick change into a screwdriver bit holder - if that would keep them sitting `tight & straight` ?
I have not tried one yet - as I have quite a stock of 25mm Flatbits.
For Flatbits - I have been buying Bosch and Draper Flatbits for years and I would recommend either brand - but I occasionally get a couple of inexpensive `Silverline` ones - You really can tell after a few holes the `good quality` bits from the `cheap`ones.
If any Members do try the `Wood Beaver` bits I would appreciate their Review please.
Regards,
Chris
I have a set of the Bosch bits and the are good be wary if using in a bit holder (being lazy) as near the bottom where the indent is in the hex it can shear off if you get a little boisterous with the drill.
I was doing a premier inn recently all timber framed drilling thousands of holes for the bedrooms. I used flat bits all variets and also CK Auger drill bits they are all good until you hit a nail !!!
What I did use was a 18v Millwaukee Brushless FPD combi 135nm or torque very good piece of kit.
Good price too..
A beast of a drill goes through RSJ's like butter.
# only bad point is the chuck is to smooth to grip after a while I'm considering putting a Makita chuck on mine.
Cheers
Armeg 16 Piece Twister Drilling Set - For Impact Drivers - https://www.buybrandtools.com/acatalog/armeg-twister-drilling-set-impact-rated-16pc.html?gclid=Cj0KCQiA2NXTBRDoARIsAJRIvLwhrXO7IJUtXqD9lACh_CYQD5vfBqr9YVkbib2WO0vpgbi3v_hVGykaAnBDEALw_wcB
Armeg Nail proof wood beavers are the Bees Knees you get a 20 and 25 with this kit which is expensive but the other bits are brill imho. I've done many jobs with just this kit and an impact driver.
Also I broke the 3mm bit and they sent me a new one and the shank snapped on the 25mm and they sent me a new one - they wouldn't replace the 20mm one that I dropped down a cavity thought. The masonry bits are multi material and go through wood pretty well too.
MAKITA DHP481Z 18V BRUSHLESS - it hurts when it kicks back - I have to use the long handle on slow speed cutting 100mm holes in floor boards - also use a Makita angle drill and that works well too. DeWalt should be OK tooI would've thought, although I don't know how the torque compares.
DROOL.
Hello All,
Regards,
Chris
I use the Armeg Wood Beavers and would highly recommend them. They go through all kinds of wood speedily and are long-lasting.
Hello JK-Electrical,
Thanks for the recommendation - your comments are similar to what I had previously read about the Armeg Wood Beaver Bits.
Regards,
Chris
too late in the day to recommend anything but what i got at this moment in time. a generous measure of Famous Grouse, and Dark Side of the Moon LP on loud. BLISS, AND SOD THE JOISTS. THEY'LL STILL BE THERE MONDAY.
Makes perfect sense!
Armeg Wood Beaver & Nail Proof Stubby (and full-size) fluted bits 20, 25 & 32 mm make very short work of joists, sheet materials, pipes etc and the nail-proof are designed to cope with the additional abuse met out by an impact driver.
60v De Walt kit eh? Hmmmmm
Reply to Flat bits, what do you recommend? in the Electrical Tools and Products area at ElectriciansForums.net
I’m new-ish to the trade and going to be working on site in a new build block of flats as an Adult trainee/apprentice, I’ve been told to bring my...
5K
Currently I’m using freeagents platform for invoicing and it’s decent and gets the job done but it’s lacking a few features. Firstly I want to be...
This might come across as a really daft question to people who work with cable tray quite often but as part of my AM2, I am to clip FP200 to the...
Hello fellow sparks, I’ve decided to go out on my own. Recently bought a little van and trying to get myself set up whilst keeping my costs as...
Hi guys, I never really come on here to be honest, but I thought I’d get the opinion of a world of unknown to me electrical contractors because...
