Discuss Flex used in domestic install in the UK Electrical Forum area at ElectriciansForums.net
Hi I have been asked to carry out a second fix on a house another spark wired and now hasn't time to do. When looking at the job I noticed he had used 1.5 t&e from the consumer unit to the first smoke detector then looped around in 4 core flex. Them same was doe on the 2 way Switching extractor fans and room stats. I personally use 3 core and earth. What is people's views on this?
There is no reason why flexible cables cannot be used, providing the csa is sufficient for the purpose. Possibly Spark #1 had a roll of 4-core flex on the van he wanted to use up.
You sure it wasn’t a plumber or hvac guy who wired the job..
Seen a few of these type jobs all wired up in flex
It's pretty clear in the Regs that it is permissible. That's not to say that many wouldn't consider it poor practice though, and given that it's more expensive to do it this way it's hard to see what is gained. I bet he hadn't intended ferruling the ends either.
Reply to Flex used in domestic install in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Got an antique light fitting that for some reason she wants putting up (can't say I love it haha) however it didn't come with any...
Hi all, I'd like to replace some MR16 halogen fittings on an exposed wooden beam to new GU10 fittings which I will be fitting led lamps into. The...
  • Locked
5K
Hi All, Im quoting to install an EV charger (Dont worry - fully registered, but only been 2 weeks so i'm still picking bits up). Consumer unit...
