I like the uplighter idea but I think 30 watt LED lamps would be more of a wall and ceiling washer type effect :)
There is a driver in the back of the floodlight which I bench tested and my scope shows it's output is constant current across varying loads so it tests okay. The SMD LED is entirely open circuit both directions and as I was dismantling it I noticed it was slightly skew because it had snagged on the aluminum reflector during original assembly. Consequently it wasn't hard against the heat sink so it probably overheated.
With the new SMD chip I'll run it with the original driver and check the voltage and current to make sure the power consumption is < 30watts. I'll also check the running temperature of the chip is <60 degrees C. Hopefully if both those factors are correct it should run fine but I guess time will tell.
I usually buy from this lot:
Flood Lights - LED Flood Lights
I've installed 10W, 30W and 50W. Reasonably priced, if you log in as a trade buyer, and no problems with the lights so far.
Always use a separate PIR though. I don't trust the integral ones, and with separate you get a more reliable product (at a price) and you're not restricted on sensing direction.
also, if the PIR fails, with separates you ain't got to replace the LED fitting as well.
