Hi all- I'm getting my Fluke 1653B calibrated for the first time, and wondered which type of calibration I need to go for?
a ) Traceable to ISO 9001
b) Accredited ( ISO 17025 ) UKAS measurement only
c ) Accredited ( ISO 17025 ) UKAS pre+ post results.
Thanks for any advice you can give.
I was wondering whether one of the two latter options might be a requirement for insurance purposes.
the options mean:
a) the calibration house has a quality system, but doesn't say anything specific about the accuracy of the calibration they perform. Nevertheless the results should be traceable to national standards. Their ISO9001 quality system should have a "scope of registration" which should tell you about what service they provide.
b) the calibration house has been certified to the relevant standard for a calibration house, the results will be traceable to national standards, any adjustments required to put the instrument within calibration limits will be done, and you get a copy of the results (after calibration) so you can see exactly what, if any, errors remain in your future measurements.
c) as b), but the calibration house will check all the ranges of the instrument before they do any adjustments, so you get pre-cal and post-cal results. This enables you to see if your instrument was giving correct readings for your recent work. If it wasn't, you might decide to go back and check a measurement if the pre-cal results are way off!
A contractor with lots of instruments might be interested in seeing whether their equipment is always still in calibration when it's sent off for re-cal. If so they can accumulate evidence to argue the calibration interval can be extended - eg do the instrument once every 2 years rather than annually (or whatever the specified interval is).
Pick the one you're happy with, and be prepared to justify the decision to your "assessor"!
The ISO 9001 will probably do.
If you owned instrument calibration equipment, to do your own calibration, you would want it calibrated under ISO 17025, but not many do their own calibration!
They get more expensive from a) to c)!
Good Afternoon
Please remember that the calibration house / laboratory were you take your instruments to , has to be certified with ISO 9001, up to the moment ISO 9001:2015 standard and will follow the BSI calibrating procedure according to ISO 17025:2017 which is currently the latest version of the ISO norm. As always in case of doubt ask an expert
