Discuss Fluorescent to LED conversion tombstone removal in the USA area at ElectriciansForums.net
I have about 30 4 bulb 4ft shop lights that I want to convert from fluorescent to LED. I need to swap the tombstones from shunted to unshunted on one side to do this. I can’t for the life of me figure out how to remove the metal tab that the tombstones anchor in to. There are no tabs on it to use a screwdriver. Outside of drilling my own tabs into it is there something I’m missing? Thanks in advance
You beat me to it just sussed it :)
Those points you have arrowed look spot welded.
[automerge]1567439534[/automerge]
I suspect that fitting is pretty maintenance free aside from the control gear cover. Can you show a pic with the tubes removed.
Maybe drill rivets out? Seems a bit extreme though.
can you not just rejig the internal wiring?
I have about 30 4 bulb 4ft shop lights that I want to convert from fluorescent to LED. I need to swap the tombstones from shunted to unshunted on one side to do this. I can’t for the life of me figure out how to remove the metal tab that the tombstones anchor in to. There are no tabs on it to use a screwdriver. Outside of drilling my own tabs into it is there something I’m missing? Thanks in advance View attachment 51848
Collab take the bulbs out then take your hand pinch both sides and it should come right off. Turn power off
Reply to Fluorescent to LED conversion tombstone removal in the USA area at ElectriciansForums.net
I'm encountering a problem with the lighting in my kitchen. I reside in an apartment that has a light fixture utilizing 2 T8 fluorescent bulbs...
I’ve got bad ballasts and am replacing the T12 fluorescent bulbs with Halco direct wire, double ended T8 LEDs. The fixture has 4Rapid start bulbs...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
I have a 4-bulb fluorescent light, previously wired for T-12?, now wired for T-8, with a bad ballasts. I think my tombstones are non-shunted. It...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
