Discuss Fluorescent tubes flickering at ends? in the UK Electrical Forum area at ElectriciansForums.net
-Matt
Hi Guys, I fitted a couple of these the other day:
http://www.NoLinkingToThis/p/lap-t8-high-frequency-weatherproof-batten-2-x-58w-5ft-1565mm/60410
I've used these before, and always been fine.
however all the tubes seem to flicker badly at just the ends.
im thinking this could be a symptom of cheap or bad batch of tubes, rather than the ballast etc?
obviously I could take them back, but if new tubes solve this, that would be better.
So do you guys agree this could be the tubes rather than the ballast's etc?
cheers,
Matt
You would be unlucky to have got two bad fittings at once, so I would be thinking tubes, the easy answer is to try different tubes.
The flickering should not be generated by the fitting (or at least not at a visible level).
cheers,
Matt
This happened to me once tested everything and it was fine, then it turned out to be just one of the tubes was faulty which made them both not work for some reason, Most likely tubes mate
Did you give them a few minutes to settle down ? I find that some brand new tubes start of with a slight flicker and dim in the middle when energised for the first time , although this soon settles down normally.
Reply to Fluorescent tubes flickering at ends? in the UK Electrical Forum area at ElectriciansForums.net
I’ve got bad ballasts and am replacing the T12 fluorescent bulbs with Halco direct wire, double ended T8 LEDs. The fixture has 4Rapid start bulbs...
A few months ago, I replaced a T8 fluorescent tube that my late father installed, with another tube of similar dimensions. The lighting still...
So T8 LED tubes that can be directly connected to 240v L+N are now available. (sold at TLC here) . They don't need any magnetic or electronic...
The lighting on my boat includes about thirty T5 8W 12" tubes in conventional 12V fittings of good make (mainly Labcraft) with HF inverters...
Hi Guys, Can you mix Hi Frequency Fluorescent fittings with Led fittings on the same radial circuit? Have 2 led fittings flickering. I know it...
