Discuss Fly Leads on banjos (and naked Ladies!) in the UK Electrical Forum area at ElectriciansForums.net
VoltzElectrical
I have always used the panel to earth the (bolted) banjos but in my new job seem to be being sent around putting on fly leads from the bolts to the Earth bar. I'm told that this has been picked up by the NIC.
I should clarify. The jobs I am being sent back on are not my own, but old(er) installations that have been inspected many times previously, but now its seems this is now an issue. Has the NIC issued new edicts regarding this issue?
Surely a simple continuity test from the banjo to the earth bar would verify that the panel is doing it's job?
Voltz
I can't specifically answer what the NIC's position is on this (you would need to ask them directly), but I always like to see flyleads from the banjo to the earth bar.
Can someone enlighten me to the naked ladies joke, or is it a private joke.
Voltz uses the enticement of the fairer sex declothed to draw is to his thread starts! Like we need that! It's our nosiness alone that makes us read threads, we're simple folk tha nos!
Not private, but it got your attention. I just wish i could think of more enticing thread starters! What size of fly lead indeed? I would like more guidance on this with some firm science behind it too. other than the NIC say so.
Voltz
I like to see a flylead if it bypasses bits of steel subject to corrosion. Steel is not as good a conductor as copper but it's fine to use as a cpc e.g. in the form of trunking or conduit, so long as it doesn't corrode. There are lots of situations where it does exactly that, and gland entries where brass parts are in contact with panels of dubious corrosion-resistance in damp environments can eventually lose their connection. A non-ferrous path from banjo to earth block could be more reliable, up to the point where the steel lets go of the gland altogether. Provided of course you don't use some wussy roofing bolt that can't be torqued up properly and might corrode faster than the cabinet once its cheapo zinc plating is gone, instead of proper NP brass bolt, washer, nut and locknut. Of course there are lots of situations where a flylead wouldn't add anything useful, e.g. galv adaptable box indoors with multiple SWA entries, where I wouldn't bother with one.
Sizewise, because the flylead is short, its resistance contribution to the circuit is minimal, so the only criterion is current rating. I often use the same size as the CPC for consistency, but in a circuit sized due to VD or grouping it can be smaller.
Lucien, we are talking of panels in dry conditions in primary schools with no evidence of corrosion. SWA bolted to the panel using roofing bolts, been tested and inspected for years, now suddenly it's an issue. I was thinking of using 4mm2 for the fly lead.
Reply to Fly Leads on banjos (and naked Ladies!) in the UK Electrical Forum area at ElectriciansForums.net
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hi I've got a megger mft 1720 that I was hoping any one can shed any light on When performing continuity tests (even when nulling the leads)...
Hi there, long time lurker, first time poster here. Straight down to it.. A friend asked me to add some sockets and additional lights to a small...
  • Locked
5K
Just carried out an EICR on a flat that was wired in the 70s - with singles run in earthed conduit to each point and the trunking providing the...
4K
