Discuss for all you tool tarts out there. in the Electrical Tools and Products area at ElectriciansForums.net
telectrix
Mentor
just received this item. multimeter with waveform graph. unbelievably only £47 inc. shippling. what will them chinese get up to next?
Are you going to do a 'review' on it?
Bung it on a dimmer switch and see how accurate the graph is.
will give it a try sometime soon. expect to see a funny waveform from a dimmer.
Like it :) Have you got the additional nipple-clips? ....we'd like to see your heart beat,in wave form...
ok, so this is the output waveform from a 400watt dimmer supplying a 60 watt load at approx, 75% full. and @darkwood. it's not a sticker. :(:(:(.
still playing with it. not worked it all out yet. obviously, not as accurate as a calibrated scope. can expand or reduce the timebase. more play tomorrow after i've fixed the oven, mown the lawn, sorted the dogs and ducks out etc., etc.
which model> i have a later model 8 and an avo megger digital thing, forget the model.
just a techybit for trainees.
the green is the input waveform as expected, and is passed straight through the dimmer when on non-dimmed. the red section is cut trailing edge as preferred by LEDs. it's so-called because the dimmer electronics cut the trailing edge, as opposed to the leading edge.
Reply to for all you tool tarts out there. in the Electrical Tools and Products area at ElectriciansForums.net
Register your Klein Tools online today to access tool details and protect yourself against tool theft! If you own Klein Tools in the USA or the...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
Hi All, this forum was incredibly helpful when I last posted. I'm a girlfriend (hoping to level up soon) to a man who is just starting his...
Hi All, My triton martinique shower suddenly became only lukewarm, i get my trusty multimeter out and sure enough, one of the heater coils has...
the romex wire itself isnt stripped. you just treat it like cat 5. with a "call for a quote" price to buy the tool. I ran into t these in a mobile...
