Discuss fusebox re: bathroom in the Canada area at ElectriciansForums.net
S
SteveR
I've got to install an electric shower and a 12v fan in a bathroom and move the existing light fitting. the fusebox is a split load rcd board, do I have to fit a new dual rcd fusebox to cover the fan?
hi matey, suppose you got a few options really, put shower on rcd side of board, or give it its own RCBO (be tempted with the later?), the 12v fan, is this a fresh installation; ie. new supply from lighting circuit to fan isolator etc, more than likely it is or even if it isnt then the cabling your working with is probably less than 50mm from the surface so id put the lighting on rcd/rcbo as well, how much room you got in the board?
rich
cheers Rich
I've only got one spare way on the rcd side of the board, it looks like I'm going to have to change the board.
thanks for the advice.
Reply to fusebox re: bathroom in the Canada area at ElectriciansForums.net
I put some news lights in a bathroom and new extractor fan. Did the tests and filled out form. A couple of days later another electrician came in...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
I've installed a replacement bathroom extractor fan. Pic on the left is the old one. Pic on right is the new one. Wired the same way but the fan...
