Neptune
We have a garage attached to the property and are having it converted to an office with a small toilet. Electrics will include, internal lights, an external light, a few sockets and a extractor fan.
There is a cable coming into the garage currently from the house and is connected into the main consumer unit. It's a 2.5mm T&E cable wired into a 32amp MCB. It has RCD protection.
I think it would be okay to use the existing cable as a radial circuit for a few sockets and also have it initially split into a FCU (3amp Fuse) and have this running a lighting circuit? I would use 2.5mm cable for the sockets and 1.5mm cable for the lights. Would this be okay?
If yes, what would happen, if the load on the sockets was higher than intended? I assume it would trip the breaker in the house
Alternatively, what would be the advantages of using one of these?
www.toolstation.com
I could have the incoming cable going into this RCD and have a Ring for the sockets and a separate circuit for internal and one further for the external lights.
Can I please have your advice on the above. Thanks in advance.
Axiom Metal Garage/Workshop Consumer Unit 3 Way | Toolstation
BS 7671 IET Amendment 3. BS 61439-3. • 1 x 63A 30mA RCD • 3 x Type B MCB (1 x 32A, 1 X16A 1 x 6A) • Dimensions: (HxWxD) 185 x 145 x 110mm
www.toolstation.com
