Discuss General RCBO installation in the UK Electrical Forum area at ElectriciansForums.net
Crumps
Hi all
I work on site as a contractor and my colleague was talking to one of the in house electricians on site. He does some work of site for somebody else and the conversation turned to RCBO installation briefly. My colleague stated he was installation last week and this in house electrician stated that they are easier than normal circuit breakers as you just put the cable anywhere on the neutral bar, doesn't matter about order.
Now to me this doesn't seem very professional. You should still install them in order as they go along, ie breaker 1 in neutral 1 for at least 2 main reasons.
1. Because you can make it look neater and more professional
2. When you come to have to do something in the board it makes it a lot easier to locate which cable goes to which breaker and do the job quicker and easier.
Just wondering how many people think this way as well?
The neutral & earth bars have termination numbers which correspond to their respective circuits, therefore, it is imperative that they actually do correspond with each other
He was probably alluding to the fact that there is one neutral bar and one earth bar so not needing to make sure it’s one neutral bar or the other.
I can’t see any willing spark putting them in haphazardly. They would follow numerics for neatness and ease of location.
Thanks, my first thought was that he was wrong. I believe he was just talking about single and not a split unit.
I personally, not even talking about the regs, would put them in order just to make it neater and easier for the next person who might need to do some work on the board.
And he isn't my mate. :)
I recently took apart a little 3036 board and the original sparks had put all Ns in one terminal and all CPCs in one terminal , actually looked quite nifty
Talking of earth terminals.....
This boiler control box earthing looks really nifty:)
Reply to General RCBO installation in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
Im just curious as to peoples thoughts on the following install I seen on a video from an Electrical firm today and they did the following: Ran...
Help please! I need a Tesla Gen 2 EV charger fitted in my garage which is 22m from the consumer unit. My electrician is proposing to route a 6mm...
Hello, I have a hypothetical question (I'm an electrical engineer) to better understand RCBOs and how they are used in the USA. Let's say I would...
