Discuss GFCI and Federal Pacific Question in the UK Electrical Forum area at ElectriciansForums.net
e50095
Hey guys. I appreciate any guidance you can offer. I'm selling my house and it got inspected today, and I have 2 questions if you can help me out. First, the inspector indicated I need to install GFCI outlets in my kitchen and bathroom. My house is a 1955 brick rancher. I'm nearly positive I read that homes built prior to 1971 are not required to have GFCI outlets unless the wiring was being upgraded, which mine is not. Am I wrong about that?
Second, he failed the single breaker box under my main because it's a fed pac stab lock. I understand they're dangerous. My question is what is the virtue of having a single breaker box? It's a 20 amp circuit, and my Square D main panel has plenty of room. Why would it be mounted separately in its own box (see pic). I appreciate any input guys.
Reply to GFCI and Federal Pacific Question in the UK Electrical Forum area at ElectriciansForums.net
Hello and thank you for your time. In the picture, the 6/3 gauge NMD wire is running though the basement ceiling and out of the house into the...
Hi, My hot tub keeps tripping after 12 years of use. I'm thinking it's the GFCI gone bad. Unfortunately it's a CH 2 pole 50 amp (GFTCB250) and...
Upfront disclosure, I am a DIY homeowner with basic knowledge of electrical safety. Here is my issue: Type GFCI Outlet- Eaton TR Installed mid to...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Background Two weeks ago, lightning struck a tree in our yard. Many circuits tripped and several electronic devices failed. There was a strong...
