Discuss Ground Lights in paving / tiling in the UK Electrical Forum area at ElectriciansForums.net
Hi team, I'm after some installation advice.
I am a spark, city & guilds 2365 L2 & L3, AM2 next month and just starting out on my own over the last few months.
I've been asked by a customer to install some uplighters / walk over lights in a conservatory. The floor hasn't been laid yet, but is imminent, (I've had three days notice). Concrete is due to go down with tiles / thin slabs due to be laid on top. They've asked for around 10 x GU10 walkover lights. The conservatory, walls and ceiling are completely glass. I was planning to run a switched fused spur from a nearby socket, and run the conservatory in steel conduit down the wall which is naked brick and then into the concrete floor.
Tapping on on the more experienced among you, is there is chemical reason I can't put steel conduit down and allow the concrete to set around it? I was thinking to put T pieces down at each light and run it in singles. But here's my main question, at the point of each light at the T piece - how would you prepare for the light fitting? The customer tells me that the concrete and the tiles combined are around 80mm in depth.
TT installation in case it's relevant, RCD main switch.
Any insight at all gratefully received.
Many Thanks - Mike
Sounds a good idea,but practically a nightmare.
The difficulty in actually getting the conduit in the right positions & connecting the lights,would be a problem.
Plastic ducting,& rubber flexes May be the answer,having t pieces at each light,then fitting the sprockets to these.
Galv conduit is ok.
The actual lamps are still undecided, I don’t think I’d pick anything as big as 50w, the lights are purely decorative rather than useful lights. But I appreciate the answers so far, I’m glad it’s not just me querying the ease of this! Thank you!
Back to the op .... typical patio type lights are 2w leds at the most, often less .......
If you do quote the customer make 100% sure, in writing, that they are happy with the solution before you install it ..
Reply to Ground Lights in paving / tiling in the UK Electrical Forum area at ElectriciansForums.net
At long last my wife is getting her new kitchen and the contractor will be running 10 or so new circuits from a new sub panel. The sub panel...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
Hi, this is a repost of the initial in diy as the only potential diy aspect is the prep ahead of a qualified person attending, this is hopefully...
Good Afternoon All, So I have a new situation to me that I cannot seem to get a definitive answer for. I trained as an electrician and did...
