R
Rudie
Hi,
I originally had this post:
http://www.electriciansforums.co.uk...ical-forum/71644-connect-2nd-siren-box-7.html
to add a 2nd siren box. I am trying to add a gsm auto dialler, but the issue i have now is that the voltage on BELL +- and STROBE +- does not change when the alarm is activated. i have had the gsm unit tested and it does work on both + and - triggering. so the gsm box needs the voltage to either drop to 0v or jump to 12v in order to activate the unit. my neighbour has the same alarm fitted as me but only 1 siren box and the unit works on his.
thanks in advance....
the + voltage won't change. it's the - that triggers bell and strobe. have you got a diagram of how you've wired it.?
its one i bought off ebay. sends me text messages and the sim needs to have numbers stored as #1, #2 etc. dont think it has a brand on the box...
Have this feeling its an imported china job.....looking back on your posts one of us could have supplied & fitted new new digital system with texted digi for £300
It's a U.K. based seller and spoke to him a few times and we have proved the unit works fine it's a grounding issue in the alarm system. Unit is made in uk.
Is that your strobe (-) connected to SCB negative ? In your picture? If so is your strobe always flashing?
And I take it you have borrowed a 12+ in the sounder enclosure ? If not your strobe will not work full stop
No simlec. the strobe - and scb - are not directly connected.
TJ Anderson - yes it is a mess. Courtesy of Assure Alarms. Never use them again.
Mine is an older version of this:
Auto Dialer Manual
ok as suspected it is a china import, and will not work with 3 or vodafone pay as you go.....but will work with o2...supply connected to aux, and input 1 to bell + & -
i have a EE sim in it. ive tried connecting input 1 to bell + or bell - without any luck. my version has jumpers on the board for + and - triggering
Rudie,
Rudie,
