Discuss Hager Bluetooth AFDD/MCB/RCD Module in the UK Electrical Forum area at ElectriciansForums.net
Very interesting video. The standby current of 0.5W = 4.4kWh per year or about two quid, but unlikely to be a big drain compared to all of the other "always on" stuff folks have.
A check on Edward Bros shows they are about £101 just now:
Still, if I had to use them then the trip diagnostics looks well worth it, as well as the switch-neutral to make testing easier (and fractionally safer should anyone reverse the supply polarity, etc).
They don't seem to offer any 10kA versions for commercial TPN style boards, but I guess that is rare for now (though with domestic 3P likely to risk only a matter of time...)
I saw a vid ( I will try to find it ) where MK are designing something very similar blue tooth AFFDDDs where you can turn them on / off from your phone or tablet. You can also monitor current draw , check on fault times etc etc
I fitted a board full if hager afdds earlier this year, i checked firmware with the app at the time and were all up to date, went back for something last week and thought ill have a little check, well theres new firmware available. Each afdd has to be connected one at a time, and to update the firmware it asks you to disconnect the outgoing cables from each one! Fun
Hourly rate
terminator 2 money GIF
That's going to impress customers - an annual service on the bloody fuse box.
Reply to Hager Bluetooth AFDD/MCB/RCD Module in the UK Electrical Forum area at ElectriciansForums.net
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
Been looking at what type RCD should be fitted for small single phase individual UPS. Looked at Hager rcd selection guide under type B has 3...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Hi Guys, Long time member and not a regular user here. I do pop in here when the odd unknown pop's up and unable to locate an electrical dilemma...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
