Hi,
This morning in my local wholesalers they had a selection of the latest Hager metal consumer units that comply with amendment 3. I have to say I was quite impressed with the look of them, especially the Design 30.
Bit late here... I do like the new Hager Design range. Previously we installed the Hager insulated range for domestic jobs as they are self extinguishing. I set fire to an MK insulated enclosure a while ago on purpose and when it got going it really went up.
The two things that I thought were responsible for the increase in fires are:
1. Rubbish quality switchgear. e.g. Volex recalls etc...
2. Incorrect / poor installation, we always terminate boards with a torque screwdriver.
It does stagger me the amount of dangerous and non compliant work carried out and the price some people will carry work out for (easy to make things work, difficult to make safe and compliant). Then they probably haven't spent £100.00 on a torque screwdriver!
You don't need a torque screwdriver IMO, I've Been fine for years without one. I agree that shyte quality is a major contribution.
Truesay, but it's the best way to show someone how tight to do things up (especially if they are a bit weak wristed) and at least you are covering yourself.
Also it's the only mcb driver blade I have and fits the terminals lovely.
Do you find the manufacturers recommended torque setting can sometimes be to tight?
Given the considerable in depth research you have undertaken on the subject of this new 'requirement' please can you direct me to the evidence that has come to light that these CU fires are caused by Electrical Trainee? I ask out of genuine interest not as provocation. I still maintain that statistics can be manipulated read whatever a person wants. Politicians do it all the time.
Like I have said a thousand bloody times, there is no 'direct' evidence, however the numbers are clear to see for anyone who isn't burying their head in the sand!
https://www.gov.uk/government/statistics/fire-statistics-great-britain-2013-to-2014
Do the research yourself. All the relevant numbers are there, no figure manipulation either.
Notice how fires caused by electrical distribution in dwellings is on a very very slow decline until 2005, the year that Part P was introduced, then notice a sharp rise.
I suppose this is just coincidence right?! I suppose the manufacturers just decided to start making their gear rubbish in 2005 and that's the cause right?!
Come on man, take your bleedin' blinkers off will you!
And how often when that torque driver been dropped is it recalibrated or how many times do you check it's calibration might be a good tool but IMO needs too much ongoing maintenance to provide accurate and repeatable results
Why did Hager provide a back cable entry plate, but nothing for their top & bottom entry boards. Grommet strip I know, but just seems a bit daft. And wholesalers seemed to struggle having in stock standard boards, but here you either have to have a back entry board or a top & bottom one. The Wylex one I've seen, just has standard knockouts. Not saying that's better, but don't think you be able to get a Hager one off the shelves. Hager one looks nicer than the Wylex though.
Just thought I'd try and get thread back on track :-)
(Somebody beat me to it). And what about cable entry for TT supply? Wylex provide 32mm black (yuck) plastic gland.
there were some 2" plastic stuffing glands in eddys the other day, bring your swa in through that. (we regually use 20,25 and 32mm stuffers)
i dont see why people bother with torque drivers
i doubt you have one that will work to the set figure on all the gear you use so you will need multiple, do it up tight with a pz/sl and it will be fine (pz/sl is mcb driver)
The dash to fit smart meters has resulted in many installations being disturbed by unqualified “operatives”.
Two interesting points that are worth considering:
When did they start fitting these meters?
When did the dramatic rise in “fuse board” fires start?
To the best of my knowledge these meter fitters aren’t allowed to open a CU to check the tails they have disturbed. As for checking the terminations in the head, that I don’t know.
If the real source of the fire could be attributed to one of the three major components in an install, IE, the head, the meter or the CU then some logical conclusions could be reached.
Statistic recording the dates and location of meter installations and the dates and locations of “electrical fires” could prove interesting.
Looking at it, going back to metal service heads and meters would be the next logical step for the LFB to twist the IET’s limp wrist. But we all know that won’t happen because the DNO’s and energy companies will turn around and tell the IET they have no authority in the distribution industry and get stuffed.
Market Harborough
Hager Metal Consumer Units
uksparks,
Midwest,
