Discuss Hardwiring under cabinet lights in the UK Electrical Forum area at ElectriciansForums.net
It's never going to end this one :)
A 13A socket on top of a cupboard is not going to cause any problems. It's not even as if it will be available for general use anyway, as the lights will always be plugged into it.
The 13A socket will often be the most suitable means of connection, since most freestanding/table luminaires are supplied with a moulded 13A plugtop. Whilst 2A or 5A BS546 sockets do offer the benefit of being less likely to be misused for appliances with greater current draw, the downside is, an Ordinary Person will more often than not be the one to cut the moulded plugtop from the luminaire and fit the BS546 plugtop, often badly. Then they chuck the non-rewirable, moulded 13A plugtop into the waste basket, with fuse intact and bare copper exposed, ready for an inquisitive kid to retrieve and take to their bedroom. Months later when the luminaire is moved to a different room, or area without BS546 outlets, it again requires rewiring by an Ordinary Person.
If a child is rummaging in bins to find things to play with then it's owner needs to take better control of it!
Its owner Dave, really ? :laughing:
[automerge]1567540110[/automerge]
Whenever I cut a moulded 13 amp plug off I always twist the live and neutral pins round with a pliers to prevent it ever being plugged in to anything ever again before binning it Tony, only takes a few seconds.
Thousands of examples of bad practice does,'t make it right. Imagine someone, maybe a wife, going up there and deciding it needs a clean, lugging a high power vacuum cleaner up, and plunging the place into darkness with no floor boards there!...
That's ok George... we're in the EU over here... we're not allowed high powered vacuum cleaners !
Can you use an FCU with flex outlet?
https://www.NoLinkingToThis/p/schne...fused-connection-unit-flex-outlet-white/3211j
Then you keep the right fuse rating for the LED driver.
AC/DC???? It all sounds like a highway to hell to me.
:):D:p
Seriously though... if there’s space down the back of the units, just drop the lights down there, driver on top of unit, hidden... and plugged in.
Most of these LED kits come with one driver with a number of outputs. If plugging in multiple lights into one, just make sure the total load on each driver doesn’t exceed the max stated output of the driver.
Reply to Hardwiring under cabinet lights in the UK Electrical Forum area at ElectriciansForums.net
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
My wife has a electric heated airer, our dog chewed through the cable and I thought it would be no different from rewiring a plug. It's not. I...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi.. Newby here.. I have a couple lights holders/bulbs on the end of a flex plugged into the mains 13Amp plug. I want to put an inline switch on...
