S
specs
Good morning Chris, I am entirely in agreement with your comments regarding 'balancing the system' . Over the years the company I work for has employed many so called 'Heating Engineers' .The pic shows an install that could have been done by one of these 'tradesmen'. I have been on many a callout where a tenant has complained that certain rads don't get warm where as others are roasting hot, when I have checked the valves they are all on full (both sides of the rad ) and as a quick fix I have turned down the valves on the 'hot' rads . This does the trick in most cases, I am not saying I have sorted out the problem completely as clearly the system requires balancing and checking for air locks maybe even a central heating pump or whatever. My next job is to arrange for the 'Heating Engineer ' to attend and sort out the problem properly. My experience of some of these characters is not good. As a company we employ these people on a yearly contract to service the systems and do the annual check and issue certs as appropriate, and on occasion to install new boilers. If the system needed to be drained for a leaking joint say somewhere near the boiler I would expect the engineer (not me) to deal with it as they saw fit and if they decided to lock down the rad valves then I would not argue as I would take it as' given' that they would know what to do , ie check amount of turns on valve. As far as taking out the plug tops on the op's pic I think your idea would have been workable if there was more space, a tad to fiddly for my liking but probably possible.
