that's what I call spaghetti junction cabling .
Wow are those un-insulated links for real?I had one similar this morning - this time CH wouldn't turn on. The wiring centre was a copy of @Leesparkykent avatar ...
Yep.Wow are those un-insulated links for real?
. They've got brooms and stuff in there and it's just luck no-ones been hurt. It also has a 3kW immersion running on 1mm flex from a 13A fcu. It was on when I got there (don't ask me why... ) and the cable and fcu were toasty. Freed up the CH valve, took fuse from immersion, secured the wiring centre top and beat a hasty retreat for today. I'll go back later in the week and make it presentable.I'm sure I can improve it, but this mob are a tough audiencepost a pic when done.
I'm sure I can improve it, but this mob are a tough audience![]()
. Top left pic shows it where I've just pulled it down away from them. Got rid of those bare links and then noticed many of the flex cables were damaged by cuts. So I went through and fixed them. Replaced the somewhat golden brown pvc flex 1mm that'd been cooked by the 3kW immersion (now high temp 2.5mm flex) and ditched the fcu for a 20A flex outlet and DP sw with some 2.5mm t&e replacing even more 1mm flex
. I'm not happy with the neatness of the wiring centre, but it is safer and easier to see where the cables come from.
