Discuss Help!!! Can't turn electric off!!! in the UK Electrical Forum area at ElectriciansForums.net
Doug81
Hi, I'm currently in the process of changing all my switches and sockets and I'm coming across a few problems, like no earth wire for any of the light fittings. Similarly no earth for some of the upstairs plug sockets but the worst yet is the socket in the hallway (right by the fuse box). It has both new (blue,brown,yellow/green) and old (red,black) wires looped together -not a big issue I hear you say....well it is when the old wiring is live even when the fuse box is switched off!!! How do I go about making it safe???IMG-20190202-WA0002.jpg
The red and black there is still live when the fuse board is turned off?
You have a serious problem.
How did you test that? Sore fingers?
Can you post a photo of your meter and fuseboard set up. There might be a clue as to what is wrong.
Can you safely protect those live cables from accidental touching?
How did a socket fit on that box with all that plaster taking up the top right corner?
Anyone in Nottingham up for a late night Saturday night callout?
On a side note, the lack of CPC (earth wire) is worrying on the sockets.
Not so much on the lighting as it was common in older days to not include a cpc in the cables.
It just means you shouldn't use metal switches on a circuit without a cpc
Find out where it is fed from and turn it off
Turn off the whole house if you have to.
Don't let anyone near that.
Needs better picture than that Doug - we cant even see the labelling. Which mcb are you switching off when you are as none are off now. Puzzling!
Doug - Are you saying that the red stranded cables are live with the main switch on the far left turned off ? If so I suspect some dodgy goings on within the CU where some idiot may have bodged in a way of bypassing, god knows why though.
Or if you're saying no single MCB isolates the point it's probably cross-connected circuits across two devices, DIY is all well and good but I strongly recommend you get a decent electrician in - urgently. But why on earth did you remove the socket without isolating first ??!!
Yes that's exactly what I'm saying!! Any way of switching it off??
So are you saying you had the main switch (the big red one on the left) switched off yet those wires were still live?
There was never a socket fitted to that backbone, there's too much plaster, there's only one (new) cross head screw holding the back box to the wall also.
The red and black cables look like the outer insulation doesn't enter the back box (which also looks too shiny to be any thing other than new.
What's the large black box on it's side under the meter, is that grey T&E with white tape connected to it?
I suspect we're not getting the full story here.
Reply to Help!!! Can't turn electric off!!! in the UK Electrical Forum area at ElectriciansForums.net
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
