Discuss Help needed am2 exam coming in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi Simon,
Not sure if you have sat your AM2 yet? If not I sat mine 2 weeks ago and luckily managed to pass 1st time. I have quite a bit of info on it if your interested (or anyone else).
Let me know and I either post or PM me and I will email you the info.
However the most stressful bits was the fault finding, there are 7 faults (you have to get 5). Mine were
1. RCBO keeps tripping. Ring Main - Short circuit between Neutral & Earth. You have to tell them between what two points, how you would rectify, and the tests you would perform to ensure the fix.
2. Light circuit not working - No continuity on neutral, again between what points, fix and test(s).
3. Motor not working - No continuity on neutral from CU to starter. Again fix and test(s).
4. Data fault short between pins 7 & 8. in your pack you will have the user guide to the test meter. This will show a list of all the faults the unit can detect with what lights up for each fault. Again fix and test(s).
5. Gas bonding - reading was 2.58 ohms. Not within the 0.05 ohms expected. Again fix and test(s).
6. 16A 3 phase socket had low IR reading, from socket back to isolator. Between all phases and Earth, also between All phases & neutral. Again fix and test(s).
7. CH not working although programmer calling for heat and room thermostat calling for heat. I had no continuity from Room thermostat L2 to pin 14 (i think) on DIN rail. Again fix and test(s).
Follow the spec in the pack and you should be ok. If during Test and Inspection you find any problems, you are allowed to fix.
Don't panic with the S plan. It is the easiest part of the install. Point to point and lots of it is pre-wired allow at least an hour. They do require you to use ferrules on the flex cables as easier to push into the DIN rail.
Good luck hope this helps.
Hi Simon glad to hear you passed 1st time. Is there any chance you could send me over any information you may have, would really appreciate it!
Hi Shane,
If you send me your email I will forward what I have across to you. I have also changed my personal settings (I think).
Hi would it be possible for you to send me any information you have on the AM2 as I have got mine in a couple of weeks. Would be so greatly appreciated
[automerge]1569448185[/automerge]
Hello mate can you please send it to me thanks
Hi Shane,
If you still happen to have the information you have, would it be possible to send to my email address please?
Rhys
[automerge]1589160051[/automerge]
Hi.
I have video and pictures from AM2.
If anyone need i can send me a PM
If you also have your videos and pictures of AM2 I’d be very grateful if you could also email to me.
Rhys
It said there was a new reply to this thread. Has it gone?
Currently working through these videos (walking through the pre-AM2 candidate advice pack - It's very informative)
How exactly are people getting a images/videos of the AM2 as my understanding is it's a no cameras/phones policy?
Hi.
Hi mate.. I'm having my AM2 next week starting Monday and not feeling very confident with my fault finding ability and few more bits.. Like IR Test, Pfc, .. By any chance can you send me the bits you have for the AM2? Much appreciated and Thank you for your help!
Reply to Help needed am2 exam coming in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
This might come across as a really daft question to people who work with cable tray quite often but as part of my AM2, I am to clip FP200 to the...
Hi Guys. Just wondering what people used to practice the written part of the 2391-52 exam? I have the iet exam prep book, which seems more geared...
Hi all. I recently failed a section of my AM2E assessment. Passed 7/10 but failed on some silly things I'm confident of correcting second time...
Hi Guys I am currently on the NVQ 2357 on my way for the AM2 and get fully qualified, at the moment i am doing private jobs, on the NVQ 2357 they...
Good morning all, Got my AM2E coming up and wondered if anyone had any advice for the day? Also what order you thought best to do the...
